AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Message 1 of 10
jpassociates
1377 Views, 9 Replies
Macros
I used the base plate macro and made a elongated cap plate with holes. It seems to work ok on one column line, but It needs it to mirrored on the opposite column line. It's not working, what am I doing wrong. HELP.
9 REPLIES 9
Message 2 of 10
lucis29
in reply to: jpassociates
Please add some pictures.
Mirror command only works in XY plane!!!
Message 3 of 10
jpassociates
I am using the the base plate macro. I am trying to have a 2-hole on 1-side 6" apart and at 90 deg. 2-more holes 6" apart 18"x18"x1 1/4" PL. I got it to work one side but i couldn't on the 90 deg. side. Thanks
Message 4 of 10
Rich.O.3d
from what I have seen, ASD does not play well with the mirror command
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Message 5 of 10
jpassociates
If I can't use this base plate macro for this particular plate. Could I use the plate macro and add holes where I need them? If so, How would this work.
Message 6 of 10
Do you have any chance to show it please?
Jakub Brożonowicz
Global Product Support
Message 7 of 10
jpassociates
is this ok
Message 8 of 10
Look at movie here.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Message 9 of 10
jpassociates
Thanks for the solution.
Message 10 of 10
Holes needed at clouded area. With all the hole variations for that base plate macro, I can't get it to show those clouded holes. Help please.
”Boost
”Tips
