Where can I find list and the syntax of VAR_ available for custom fill of .dwt tremplate for ASD ?
Solved by dkwolek. Go to Solution.
Solved by BarryHaugen41. Go to Solution.
If you were to search the help for 'Parameters' that gives you the list of VAR_ that you are asking about. There is no help on syntax.
Hi
Please refer to ASD web help file using following link.
http://docs.autodesk.com/STRDET/2012/ENU/filesREINF/GUID-A7B92DAB-BB50-4A44-9A63-010428E62EE-266.htm
Hope that helps
Regards
