AutoCAD Structural Detailing General DIscussion
New Member
0 Kudos
Post 1 of 4
Ladder and cage alignment with extend & direct Vertical bars (stringers)
558 Views, 3 Replies
10-15-2012 05:34 AM
Hi there,
I'm quite new to ASD but have adapted nicely so far without formal training, however I have one issue that I can't seem to figure out...
I have a catladder arrangement with vertical bars that are direct and extended (widened) at the top, when I create the cage it does not create a smooth transition along the vertical bars? Am I doing something wrong?
I have an attached picture to show what I mean.
Product Support
32 Kudos
Post 2 of 4
Re: Ladder and cage alignment with extend & direct Vertical bars (stringers)
10-16-2012 05:48 AM in reply to: marci.dup
Truly said screen is not enough.
Maybe the sample dwg file you have?
Jakub Brożonowicz
1 Kudo
Post 3 of 4
10-17-2012 04:33 AM in reply to: Jakub.Brozonowicz
Hi Jakub,
Here is the ladder and cage.dwg (2013).
Thank you!
-=StevieWonder=-
"Trust me, I'm a draftsman"
Product Support
32 Kudos
Post 4 of 4
10-18-2012 03:54 AM in reply to: StevieWonder
I am affraid that the cage is not possible to align to the extended widened vertical bars.
For me it is rather a field to improve the functionality but you can model something similar instead of it.
Look at attched model.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
