hi!
Bolts in truss connected wich column, mass properties kg/m in sections materials and fit beam beam clip angle.
errors. would be bugs?
Seems all like a bugs but to confirming these to you, I need a sample files rather to be shared.
Are you able to do it?
ASD-BUG
Seems like a bug.
With unit mass - it is a bug.
ASD shows value for kg/ft unit.
Should be 47,33 kg/m for such S section shown (check correct unit value in tables).
Works in unwanted way - it is a bug.
All problems under investigation now.
