if material is coated with zn, after that holes are 2mm smaller , is it possible to change "insert bolt" so that inserted bolts are 3-4mm smaller than holes ?
yes and i use when profile is coated with zn
but the only method i know is manual...
after bolts are placed you can select the bar or plate with holes and look Parts Edition tab there you can find all matchings about selected profile or plate
you can right click on bolt matching and modyfi bolts in this menu you can mAKE BIGGER HOLES WHITOUT RESIZE BOLTS
if i have 1000 bolts its very annoying to change one by one 🙂
it would be nice that i can make default seting so that bolt is automaticly 2-3-4mm smaller than hole..
or i can select many holes in many parts and change dia. at once
and command for remove all bolt at once so that holes remain..
and command for insert all bolts at once .
