Is AutoCAD Structural Steel 2012 a stand alone program, or an add-on program to AutoCAD 2012? I am looking to get this, but I am not sure if I have to purchase this, along with AutoCAD, or if this will work on its own.
Solved by Pawel.Pulak. Go to Solution.
ASD is integrated with AutoCAD. After installing ASD 2 shortcuts are available: ASD and pure AutoCAD.
As concerns purchasing ASD 2012 cannot be purchased alone - it is contained only in some Suites: Revit Structure Suite, Building Design Suite, Plant Design Suite Premium.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
OK, so if I were to purchase the Revit Structure suite, with ASD, then I would not need to have a new version of AutoCAD (2012 for example) for it to work properly?
No, it is not necessary.
