AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Internal Error: !saveres.cpp@154: eFilerError
18 REPLIES 18
Message 1 of 19
tedmail
16228 Views, 18 Replies
I had been working on a file for a few days without any issue.  Then, I came in this morning and can't open the file without getting the error listed in the subject.  This same error now happens to the .bak file and to the autosave files from almost a week ago even though I have succefully opened a backup file within those dates just yesterday.  It's like out of nowhere this whole project is no longer able to open.  I have tried reinstalling ASD with no change.
Any ideas?
18 REPLIES 18
Message 2 of 19
tedmail
in reply to: tedmail
This same error occurs when trying to open with Design Review or DWG TrueView.  I also could not get the DWG to DWF converter to install on my 64 bit computer.  Is there any way to recover these files?  What would have made all of them bad files over night?  It just doesn't make sense.
Message 3 of 19
You could post the files here. I will try to open them in my ASD. If everething goes well, then it is you computer.
Message 4 of 19
Wish I could, but I'm dealing with proprietary information and can't risk it.  I am going to try the old fresh install of windows and see what happens.
Message 5 of 19
Udo_Huebner
The same error is actually dicussed in a german autodesk discussion group,
You also find a sample file (DWG 2013) which produces the error.
Made with AutoCAD Architecture 2013.
http://ww3.cad.de/foren/ubb/uploads/Roema/GelanderOG.dwg
Already tested on serveral computers - always the same error.
The complete Message (in german) you will find here:
http://ww3.cad.de/foren/ubb/Forum54/HTML/029064.shtml#000000
Best regards
Udo Huebner (CAD-Huebner)
Gruß Udo Hübner (CAD-Huebner)
Message 6 of 19
salsa17
in reply to: Udo_Huebner
I just experienced the same problem.  Lost a week's worth of work.  Is there anything I can do?  Recover doesn't work on the .dwg, .bak. or .ac$ files either.
Message 7 of 19
klapproth
in reply to: salsa17
Any solutions? Same problem here. Files in backup are partially broken. We can open them, but copying every element to a new file reproduces the crash. Copying a single, simple element will work, but the dwg-file has a size of 3MB. We use AutoCAD Mechanical 2013 on Win7 64bit.
Message 8 of 19
mviscetto
in reply to: klapproth
Has anyone determined the cause / solution for this issue?
I have 28 workstations, we just rolled out 2013 and received the first error like this today.
Thank you in advance for any information that may prevent further issues.
Michael
Message 9 of 19
keithc03
SOLUTION
use the program
http://www.autodwg.com/DWG_DXF_Converter/
took a couple of goes but worked on a file for me when i saved it back to a previous version
GOOD LUCK
Message 10 of 19
Hey!!
Can you hel me pleassssse??
I have the same Error, like other guys.
But i have a Mac and i can't install the program that you sad.
So... Can i send my file to you???
Ow god, i'm nervoussssss....
Sorry about my english, but i'm braziliam and not toooo expert!! 😛
Thank u!!
Message 11 of 19
Send it to Autodesk. Unfortunately, I have no solution for it.
Message 12 of 19
here you go
I dont do this for everyone 🙂
good luck
keith
Message 13 of 19
Thank you soooooooooooo much!!
Can you tell me what did u do??
Because i'd tried in a pc with windows, with the program to converter DWG to DXF... like u said, but it not works.
sorry my english ahahha I hope u understend.
Thank u!!
Thank u!!
Message 14 of 19
Were you using Vault to check drawing in or out when you got the !saveres.cpp@154 error?
Message 15 of 19
aruss_61
in reply to: keithc03
Hi, do you think you could help recover my drawing as well? I have put tons of time in to this project, and was working on it as recently as this moring. Now, suddenly the drawing refuses to open. I have tried every AutoCAD recovery method that I can pssobily think of, NOTHING works. Every single time I attempt to open it, I get the same "Internal Error: !saveres.cpp@154: eFilerError" message.
Please help! Anyone would truly be a life saver if they can recover this file for me. It is a shame work can be in jeopardy this easily on CAD. The drawing is attached.
Message 16 of 19
aruss_61
Could you recover this one as well? Same error I am getting.Drawing won't open.
Message 17 of 19
keithc03
in reply to: aruss_61
File recovered but DATA doesnt look good to me , but hey its your data .....
Message 18 of 19
Impact
clicking on this solution gives a "Site Cannot Be Reached" error page
Message 19 of 19
jhakman
Hi there, I've had a similar issue this week, can you please assist me to open my drawing?
”Boost
”Tips
