AutoCAD Structural Detailing General DIscussion
Valued Contributor
9 Kudos
Post 1 of 2
Inserting Blocks
311 Views, 1 Replies
02-09-2011 03:55 AM
Hi
I have created some bent rods using the standard profile command and using a standard catalogue section
I have saved these files and then I have inserted them into my current model as a block. This works fine and I'm able to give the item a mark and produce a shop drawing.
After I save and exit the model and then reenter the model, the item I inserted disappears. I went over and over this in many different models with many different inserted items and always the same thing
Any suggetions out there???
Regards
Tony (Frustrated Detailer)
0 Kudos
Post 2 of 2
Re: Inserting Blocks
02-16-2011 07:51 AM in reply to: deltawaservices
Try opening up the individual file where the detail part is, copying it and then opening up your main drawing and pasting the part into it.  Inserting ASD items as blocks has never worked for us.  Also, when you copy the part make sure it does not have a position attached to it.  Position it after it is pasted in.  Hope this helps.
Post to the Community
New Post
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
