I hope to all heavans that I am missing something here, but is there a way to just import the families from a previous job? Or the "dimensioning" styles & "description" styles? It takes me almost a whole day to pick through all those variables and set them to our standard. So basically, without my template set up right now, it's taking me a whole day to start with a clean sheet. There has got to be a drawing manager in here or something that allows importing of these, no? I haven't been able to find anything online or in the help...
Solved by Pawel.Pulak. Go to Solution.
You can use ASD Center to import settings from some DWG to the current one:
But to avoid repetition it would be recommended to create DWT and set it as the defaullt one in Preferences of ASD.
I knew I was missing something when the drawing manager was no more.... Thanks!
