what are the steps for creating a view port i follow the comands but i can never get the section to come out in the view port
Can you explain what you're trying to do, and the steps you're using?
If I know what final result you're trying to achieve I could probably help.
You can cut a section, I've done it before.
I'm busy at the moment, but if someone else doesn't answer your question I'll post some screenshots of the process later today.
Now that you have worked out the solution, could you now please share the answer for the benefit of others?
