AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
How do you specify a gap / spacing in back to back double Angle profiles?
1 REPLY 1
Geoff
1025 Views, 1 Reply
How do you specify a gap / spacing in back to back double Angle profiles?  I am drawing diagonal bracing with a plate connection, but thus far haven't figured out to specify a 1/2" or 3/8" gap between the back to back angles.
Geoff
1 REPLY 1
Geoff
in reply to: Geoff
I found the answer myself - Select the Compound Profiles Icon under Elements.  Select both an initial and final point.  Then you are prompted to select certain choices, one of which is back to back angles.  From that you can select the orientation of the angles and the gap in-between.
Geoff
”Boost
”Tips
