Change name option in Object Inspector cannot rename Cut symbol in drawing.
ASD2014
See the attached photo.
When you have your cut selected in the object inspector, you should see its properties in the lower portion of the object inspector. Double click on the name of the cut (the red box is outlining this in the attached screenshot). Then you can rename your cut and make sure to hit the enter button, the changes will not take effect unless you do this.
Let me know if this works for you.
Thank you for your reply. This functionality works, sometimes. Is ASD2013 more stable than 2014 version?
This is the main reason why I'm holding on to ASD13. The devil you know or at least think you understand.
I now hit "Enter" on everything I change just in case.
