AutoCAD Structural Detailing Forum
Welcome to Autodeskā€™s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Showing results forĀ
Did you mean:Ā
horizontal splice
4 REPLIES 4
jorgeluisgdeaca
1554 Views, 4 Replies
horizontal splice
Well, It's me again asking about tapered - 3 plates - welded plates (plate girder by ASD) both columns and beams.
I need a horizontal splice  beam to column (please see the atached).
If someone works with this profiles using this connection please help me because column (plate grider macro) only offers 3 plates+top splice and I need just 3 plates.
I've tried exploding and removing the splice plate without success.
Thanks in advance
4 REPLIES 4
Maybe you need to model column as a beam and the beam as column?
Any ASD model to share to check?
Jakub Brożonowicz
Global Product Support
Sure, This is an small steel building processing to construct.
It was designed with horizontal splices as in the previous picture.
I'm sorry I can't attach this file here because it has more than 6mb, please download from:
https://www.dropbox.com/sh/k83zdxqe1wjycnj/-XneHEpdLM
Bye
Look what I was able to do after switching beam and column.
Not perfectly horizontal splice but better than nothing.
Jakub Brożonowicz
Jakub,
when I change column and beam locations some connections don't works as I was waiting.
If you look the attached some connections appears as "incorrect data" because it does not recognize them.
Any idea to solve it?
ā€Boost
ā€Tips
