Hi, I have a problem with the hidden lines of some profiles.
I have attached an example that shows the error in the Layout called Sheet 1.
There are some profiles with the same position assigned. Some show the hidden lines perfectly, but others do not.
Do you know why?
Thanks in advance.
I test ASD with a simple structure, only 6 beams.
Look at the results at the screenshot! The hidden lines of the two short beams at the bottom are missing.
I made exactly the same steps in each file:
The differences between each file are that I use in:
Any suggestion on how to correct this issue???
Thanks in advance!
