AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
tkertesz
939 Views, 5 Replies
help files
Installed ASD typically and it says it cant find the help files. Whats up with that?
5 REPLIES 5
tswierkula
in reply to: tkertesz
If you are connected to internet after press "F1" there will open a website with AutoCAD's help. If you aren't connected to internet you have to open "Options>Files>Help and...>Help File" and change to index.html.
tkertesz
Thanks but I dont understand on how to change the index. Can you explain it to me? I am rarely online when using the program and would like to be able to access help.
Tom
tkertesz
I actually got it to work.
Best regards and thanks again....
Thomas
route1286
What did you do to get it to work? I am having the same problem.
route1286
Autodesk's solution:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15068206&linkID=9240818
To disable online help:
http://www.cadforum.cz/cadforum_en/switching-online-help-in-autocad-2011-to-local-help-files-tip7289
”Boost
”Tips
