AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Help Connection ASD
2 REPLIES 2
trandtrung00
515 Views, 2 Replies
Help Connection ASD
I create a tapered beam, parametric comlum in RSAP and export it to ASD but can't connect it .Please show me the way to solve it
2 REPLIES 2
Try to recreate the beam in ASD.
In ASD tapered/3 plates/ welded plates profiles are very hard to use. You only have 3 macros and control them is also very difficult. I 've tried to using 3 welded plates (welded by me), no luck.Also you can't import these profiles from Revit plus RSA import profiles that you can't modify and use it later with previous attributes.
As Cristian says, try make them again
”Boost
”Tips
