I have started a project of Support structure, first created handrails.and everything worked fine.
I then added anopther platform with staircase on it, ASD generate handrails without connections. stanchions are made longer than given parameters.
all profiles handrails and knee rails are not mitered as on the first platform.
handrails are not welded to the stanchions as on the frist platform.
are there setting that gives an option to have the functionality back?
HulelaG, Maby you are modeling parametric structures in simlified mode, try to regenerate parametric structure in full mode (picture 001), if you want to generate parametric structures in full mode ,In project preferences unceheck simplified mode of parametric structures (picture 002), my advice is let that field checked because its consuming less memory.
