AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Grating using Plate command
1 REPLY 1
706 Views, 1 Reply
Is there a way I can trim back the plate (grating) to contour steel members. Is the plate command smart enough to detect steel, pipe and be able to contour around the objects? For example a Petro-Chemical platform
1 REPLY 1
michal.koprowski
Hello
Use command "fit to object" (fourth icon in "Machining I" toolbar).
In the dialog box you'll be able to set different variants of gap size and shape.
regards
Michał Koprowski
Lead Product Designer
michal.koprowski@autodesk.com
”Boost
”Tips
