AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Global bolt standard in ASD2012 is missing ?
2 REPLIES 2
ZHUKOV_ING
562 Views, 2 Replies
As you can see in the images below that global bolt's standard is not available in ASD 2012?
Is this a bug?
2 REPLIES 2
jad.dellel
in reply to: ZHUKOV_ING
The bolt database settings from Job Preferences available in older versions of ASD has not been supported therefore it is not available in v.2012. The correct way is to set this in the properties of the bolting in the way shown below (make sure you select the use of bolts from database rather than Auto)
The bolt database selected for the first bolted connection is then assumes as the default till the moment you change it in the same way creating a new connection.
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
ZHUKOV_ING
in reply to: jad.dellel
Thanks.
”Boost
”Tips
