Why is this stupid program doing this? It has nothing to do with the page setup because its on ANSI C and it fits just fine on all of my other printouts. It happens when I modify the dimensions usually and it will go away when I update my printout but when I update it, I lose all of my modifications on the dimensions. Is there anyway to fix this or maybe to not have my dimensions be set back to the default ones when it updates?
Here is a workaround:
Go to Template Edition and change the scale to the same scale. It will update. Also, if you don't want ASD to delete your dimensions, lock the view.
