AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Gauge Plate Thickness
6 REPLIES 6
1160 Views, 6 Replies
Is there a way to insert user defined plate thicknesses in the Plate Element tool? I need stair treads that are 10 gauge. The only choices I have are 1/8" and 3/16"...
Any ideas or am I hosed?
6 REPLIES 6
Jakub.Brozonowicz
By UNITS change the type of system on Engineering with precision 0'-0.0000".
Use attached database in C:\ProgramData\Autodesk\Structural\Common Data\2013\Data\Prof and plate thickness 0.1345"
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Global Product Support
in reply to: Jakub.Brozonowicz
Jakub-
Thank you for answering all of my questions lately. Its a huge help. How do I edit the XML file if I want to add another thickness to it?
Thanks!
Jess
Jakub.Brozonowicz
It is possible to do in notepad.
Jakub Brożonowicz
Thank you... I see the format now. Is it possible to have the new gauge thicknesses in Fractional format as well?
Again Thank you Jakub for all your help!
Jess
Jakub.Brozonowicz
You mean 10 gauge = 0.1345" = 0 269/2000?
I do not think so.
We can use precision units like 1/2, 1/4, 1/8, 1/16 etc to 1/256
Jakub Brożonowicz
Thank you Jakub. I realized after my post that it was probably a silly question.
Jess
”Boost
”Tips
