AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
From ASD to TEKLA
5 REPLIES 5
iegia
2413 Views, 5 Replies
From ASD to TEKLA
How can I export a model from ASD 2013 to TEKLA?. I have tried export DSTV (CIS/2 and DSTV) and it does not work.
5 REPLIES 5
in reply to: iegia
Good day,
Have you tried exoprting the file through ACIS and open in AutoCAD, then export to sat. format using your AutoCAD Standard?
Import the sat file into Tekla as solid body.
note that you will lose the Structural intelligence of ASD.
or Export to Robot then import to Tekla.
I am also looking for that method of Bringing the Tekla or Strucad file to ASD or Autocad  not as solid body.
iegia
Thanks, but there is some chance of not losing all the structural information?
iegia
in reply to: iegia
Are there any recommendations for exporting the model to CIS / 2? For example disable the connection layer, avoiding curved profiles ..
jad.dellel
in reply to: iegia
You can try to export first your model to Revit and after use the free Tekla application to import it from Revit.
this link could help: http://www.tekla.com/international/solutions/building-construction/Pages/export-revit-tekla-structur...
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
in reply to: iegia
When the cis/2 export creates the sat file, it ignores the profile offsets from the 'profile properties' dialogue box and 'moves' the member to be centred about its insertion line.
Is there a known work around or somwhere i can access cis/2 export options.
”Boost
”Tips
