AutoCAD Structural Detailing General DIscussion
Valued Contributor
7 Kudos
Post 1 of 6
From ASD to BIM?
1101 Views, 5 Replies
07-09-2011 07:19 AM
Any way of doing this?  I got comfertable modeling in ASD and forgot to go use Revit, and now I can't find a way to export it.
USE CIS/2 format (See pic)
CIS/2 is similar to IFC but used only for steel.
For example Tekla reads CIS/2
Revit reads only main profiles from CIS/2
If it is needed for visual , use ACIS Solids.
Member
0 Kudos
Post 2 of 6
Re: From ASD to BIM?
07-13-2011 10:41 AM in reply to: tedmail
There is a couple of ways of doing this, first one is to use the revit extension for ASD, the only problem with that is only columns and beams come across. No connections or cuts come with the export. The second way is to export as ACIS solid model and bring that as an underlay into revit, you will loose the profile sizes but all the components will be there.
Valued Contributor
17 Kudos
Post 3 of 6
07-24-2011 11:44 PM in reply to: tedmail
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Valued Mentor
65 Kudos
Post 4 of 6
Re: From ASD to BIM?....not realy...there is a BUG
10-16-2012 06:08 PM in reply to: Priitl220
that would work if there wasnt a BUG
cardinal points are ignored when the CIS/2 is exported
ie if you have your insertion line at TOS, then all your members will jump up so that the steel member profile is located with the centroid of section at TOS (all your steel will be half the member depth higher than it should be
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Distinguished Contributor
12 Kudos
Post 5 of 6
10-17-2012 09:51 AM in reply to: Rich.O.3d
Try the Navisworks export. 'NWCOUT' command. What software will be working with the model after you export it? Every single BIM job I've done was required to provide model files compatable with Navisworks Manage. NWC files are extremely small in file size as well. Nice for emailing.
Mark
Valued Mentor
65 Kudos
Post 6 of 6
10-18-2012 02:58 PM in reply to: markhubrich
you cant imprort navis cache files into other detailing programs
nwcout does not create a CIS/2 (its a CIMsteel Integration Standards file, its a type of *.sat)
Im exporting for sending to a detailer that uses Tekla, but the CIS/2 bug will still be evident when pushed into a BIM program hence the double post :smileywink:
I would have used a different work flow from the start of the project if it was up to me.
When given lemons, I try to make lemonade :smileyvery-happy:
I was commenting on the bug in the autodesk version of this output, I can turn navis pretty much inside out, but thanks for the suggestion.
CAD Management 101:
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
