AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
564 Views, 5 Replies
Frame knees
does anyone know how to design this kind of frame knee? I am beginner user so probably there is some option for this but still have no idea where. It would be better if it's possible to design this connection using separate plates i.e
firstly I have designed column and beam and then I'd like to  insert inclined plate (stiffener) in between.
Thanks for help in advance
5 REPLIES 5
Jakub.Brozonowicz
Done on HEB300 and HEAA300.
Plate inserted manually on diagonal and profiles fitted to plate object after.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Global Product Support
Can you send it once again but in less recent AutoCad version i.e less then 2012.
best greetings
Jakub.Brozonowicz
Done in ASD 2010.
Jakub Brożonowicz
in reply to: Jakub.Brozonowicz
Still struggling with that. Even though I'm trying to draw inclined plate, the only possible ( i don't know why) is horizontal one. Please find attachment with problem
lucis29
I've used:
1) Machining->"Cut to bisector"
2) Connections->"Endplates"
”Boost
”Tips
