AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Export to Revit from ASD Steel
1 REPLY 1
sureshchotrani
1033 Views, 1 Reply
When i import ASD steel structure to Revit Structure i found that connection given in ASD are not visible in Revit Structure. Also elements are getting doubled overlaping over each other. Please help me in this issues.
Suresh
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
1 REPLY 1
justin
in reply to: sureshchotrani
The thing is you not supposed to import a structure from ASD Steel back into Revit. Asd Steel is there to create the final product.
The other way is to do the steel in asd save as block and import it into revit, but you dont do any steel work in revit. You can see the steel structure but wont be able to tag the members unless you use text. You can dimension it, but that is as far as it goes.
”Boost
”Tips
