AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
ERROR ON OPENING 'DRAWING FILE IS NOT VALID'
1 REPLY 1
1785 Views, 1 Reply
PLS SOLVE THE PROBLEM AS THE FILE IS REPEATEDLY SHOWING 'DRAWING FILE IS NOT VALID' ON OPENING.THE VERSION USED ASD 2012.
PLS DO THE NEEDFUL
THANKS IN ADVANCE
1 REPLY 1
VinodBalasubramanian
This drawing file is fully corrupted and unfortunately we can't recover them. However if you have enabled autosave, you can look for the backup files.
More info can be found on this link,
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a91938...
Hope it helps.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
”Boost
”Tips
