Hallo,
there is an error message opening program in AutoCAD Structural Detailing German version 32-bit, XP,
Installed with downloades install-file:
"error while trying to read \barlib7_aci.xml file . Check if file exists on given path."
That file exists:
D:\Programme\Autodesk\AutoCAD Structural Detailing 2012 - Deutsch\STRUCTURAL_COMMON_DATA\Data\Reinf\barlib7_iso.xml
But in ASD 2010/2011/2012 the path is complete different
As "Administrator" has the same problem, it's no problem of file access permission.
Which path has to be given? Its already in "support" and "working(?)-support"
kind regards
Josef
Solved by j_zirnbauer. Go to Solution.
