AutoCAD Structural Detailing General DIscussion
RamonRUIZ4494
Message 1 of 5 (354 Views)
Error importing CIS/2 file from revit
354 Views, 4 Replies
04-15-2009 06:00 PM
Hi to all,
The error ocurre when the elements in revit do not have the same description as the ASD data base. Those elemente do not get imported :-(. A workarround will be to create from ASD the elements that I will use in my project . . then export this elements to revit as cis then I can have acces to the same properties in the revit file . . . here come the bad thing . . . then I just have to re-aply the element sizes . . . to much work . . there must be a work arround . . . thanks for the help
Carlos
Distinguished Contributor
sureshchotrani
Message 2 of 5 (354 Views)
Re: Error importing CIS/2 file from revit
04-16-2009 12:02 AM in reply to: RamonRUIZ4494
You have to first update ASD. Open ASD go in file menu/Steel/Project Preferences/Profiles/click inverted T shape for adding AISC shape/OK.
Now you can import your file & there will be no error.
Suresh
RamonRUIZ4494
Message 3 of 5 (354 Views)
04-16-2009 08:43 AM in reply to: RamonRUIZ4494
Thank yoou Suresh for the solution
Best Regards,
Carlos
New Member
robertlipman
Message 4 of 5 (354 Views)
05-08-2009 08:35 AM in reply to: RamonRUIZ4494
There is now a Google group to discuss CIS/2.
http://groups.google.com/group/cis2-group
Bob Lipman
http://cic.nist.gov/lipman/
sureshchotrani
Message 5 of 5 (354 Views)
05-09-2009 06:58 AM in reply to: RamonRUIZ4494
This was needed and I am exicted.
Thanks once again,
Suresh
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
