AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Error importing CIS/2 file from revit
4 REPLIES 4
RamonRUIZ4494
582 Views, 4 Replies
Hi to all,
The error ocurre when the elements in revit do not have the same description as the ASD data base. Those elemente do not get imported :-(. A workarround will be to create from ASD the elements that I will use in my project . . then export this elements to revit as cis then I can have acces to the same properties in the revit file . . . here come the bad thing . . . then I just have to re-aply the element sizes . . . to much work . . there must be a work arround . . . thanks for the help
Carlos
4 REPLIES 4
You have to first update ASD. Open ASD go in file menu/Steel/Project Preferences/Profiles/click inverted T shape for adding AISC shape/OK.
Now you can import your file & there will be no error.
Suresh
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Thank yoou Suresh for the solution
Best Regards,
Carlos
There is now a Google group to discuss CIS/2.
http://groups.google.com/group/cis2-group
Bob Lipman
http://cic.nist.gov/lipman/
This was needed and I am exicted.
Thanks once again,
Suresh
”Boost
”Tips
