Am having trouble with my ASD 2013 freezing when I go to start a connection, or when I click on the 'column' tile (probably among many others)
Then, to exit I CTRL+ALT+DEL and it gives me then error "the remote server does not exist or is unavailable". Not sure what is going on this has not happened before. Can't seem to find anything about this issue on the forum.
Thanks in advance for any advice.
This happened to me too. I think the problem is that the window with connection properties opens behind another window (opened program). If you have 2+ monitors the problem the occurence is higher.
The server error appears because you forced the program to close.
