AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
endplate-beam to column flange trouble (possible bug)
1 REPLY 1
823 Views, 1 Reply
In ASD (steel module), the "endplate-beam to column flange" connection does not work properly. After selecting a column and a beam, on the connection dialog box, the dimensions are not calculated correctly, the internal calculations for distanses are not being made and i cannot apply the connection to the model.
After closing the window all other ASD/Autocad commands do not work and i have to restart the application.
Any ideas?
1 REPLY 1
The problem was ocuring when i was trying to insert this connection to a new drawing, set in metric units. The "solution" i found, is first to insert a endplate-beam to column flange connection in imperial units, then to swich to metric units and insert the connection again. The .dwg file now has not this problem for the future.
Please correct this bug
”Boost
”Tips
