Hi everyone!
I'm dealing with ASD 2012 RC module and quite confused about making a formwork of a foundation slab. It has two levels (the main area and rised on 290 mm higher - additional one). I want to make a copy of existing formwork to show top and bottom rebars separated.
Would appreciate any help!
You mean slab element imported from ASD Formwork module?
Any sample file you have to share?
Yeah sure:
Here is a normal slab, I mean rectangular and with that I don't have any problems - I am able to make a copy of the top view of the slab and make the reinforcement for both upper and bottom zones.
But how can I do the same for the following slab:
I was trying to generate a kind of a slab in formwork module, but have faced with a problem: I couldn't actually unite two separate slabs (one with an offset on 290 mm lower) to form a new. Is there any solution?
