AutoCAD Structural Detailing General DIscussion
Valued Contributor
3 Kudos
Post 1 of 3
Elevation and top view ASD2012 RC
329 Views, 2 Replies
09-11-2012 06:17 AM
Hi everyone!
I'm dealing with ASD 2012 RC module and quite confused about making a formwork of a foundation slab. It has two levels (the main area and rised on 290 mm higher - additional one). I want to make a copy of existing formwork to show top and bottom rebars separated.
Would appreciate any help!
Product Support
32 Kudos
Post 2 of 3
Re: Elevation and top view ASD2012 RC
09-11-2012 07:52 AM in reply to: Ievgen
You mean slab element imported from ASD Formwork module?
Any sample file you have to share?
Jakub Brożonowicz
Valued Contributor
3 Kudos
Post 3 of 3
09-11-2012 08:50 AM in reply to: Jakub.Brozonowicz
Yeah sure:
Here is a normal slab, I mean rectangular and with that I don't have any problems - I am able to make a copy of the top view of the slab and make the reinforcement for both upper and bottom zones.
But how can I do the same for the following slab:
I was trying to generate a kind of a slab in formwork module, but have faced with a problem: I couldn't actually unite two separate slabs (one with an offset on 290 mm lower) to form a new. Is there any solution?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
