AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Elevation and top view ASD2012 RC
2 REPLIES 2
Ievgen
564 Views, 2 Replies
Hi everyone!
I'm dealing with ASD 2012 RC module and quite confused about making a formwork of a foundation slab. It has two levels (the main area and rised on 290 mm higher - additional one). I want to make a copy of existing formwork to show top and bottom rebars separated.
Would appreciate any help!
2 REPLIES 2
Jakub.Brozonowicz
in reply to: Ievgen
You mean slab element imported from ASD Formwork module?
Any sample file you have to share?
Jakub Brożonowicz
Global Product Support
Ievgen
in reply to: Jakub.Brozonowicz
Yeah sure:
Here is a normal slab, I mean rectangular and with that I don't have any problems - I am able to make a copy of the top view of the slab and make the reinforcement for both upper and bottom zones.
But how can I do the same for the following slab:
I was trying to generate a kind of a slab in formwork module, but have faced with a problem: I couldn't actually unite two separate slabs (one with an offset on 290 mm lower) to form a new. Is there any solution?
”Boost
”Tips
