Does anyone know if there is either a utility or another way to get dxf files of plates? I don't have an issue with the nc files themselves, they look real good with the scribe mark and all.
The issue is, many companies cannot open the nc or nc1 files. Everyone wants dxf files mostly. Some are requesting Solidworks files. Mainly the companies with multiaxis heads on their plasma machines.
Is there a utility to select a folder of these files and spit out a folder of dxf files? I would even settle for a command line solution. It would sure save me lots & lots of time.
Mark
Hi I cant help with your problem but I'm hopping you can help with mine.
I need to export my plated as nc files and I don’t have the fogey'st on where to start, as you said you don’t have a problem with nc files I thought you might be able to explain how to export to nc to me
