AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Drawing No
3 REPLIES 3
Delvin.Ramassami
820 Views, 3 Replies
Drawing No
How can add drawing No with reference to the beam or column position for manufacturing drawing ?
For Example :- Beam (B28)
                        Drawing No B28
3 REPLIES 3
HulelaG
in reply to: Delvin.Ramassami
Best of my knowledge on ASD is, when you apply variable Var_pos,  and Var Part. it should pick up the Drawing or Assembly number.
take note this doesnt work when you generate drawings of Assembly with multiple parts in one drawing, Make Single assembly and have parts arranged in separate drawing.
Delvin.Ramassami
in reply to: HulelaG
There a way of doing it :
While creating your template
- insert an MTEXT
- insert Field
Field Category (Others)
- System variable
Select Ctab to reference the position name of the sheet
Its more worth when inserting in a Template at first
”Boost
”Tips
