How can add drawing No with reference to the beam or column position for manufacturing drawing ?
For Example :- Beam (B28)
Drawing No B28
Solved by Delvin.Ramassami. Go to Solution.
Best of my knowledge on ASD is, when you apply variable Var_pos, and Var Part. it should pick up the Drawing or Assembly number.
take note this doesnt work when you generate drawings of Assembly with multiple parts in one drawing, Make Single assembly and have parts arranged in separate drawing.
There a way of doing it :
While creating your template
- insert an MTEXT
- insert Field
Field Category (Others)
- System variable
Select Ctab to reference the position name of the sheet
