AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Double sided shear plate connection
2 REPLIES 2
haydenwse
765 Views, 2 Replies
I can find clip angle macros for single and double sided conditions but I can only find the beam/beam shear plate for a beam on one side.  Is this connection available or do you just need to do it twice?
2 REPLIES 2
Can you please be more specific? What can  you find and what you can't?
Regards.
I think I figured out why there is double sided beam / beam clip angle macro but only the single side beam / beam shear plate macro.  On clip angles the bolts need to connect both sides so that needs to be a macro that does both sides together.  On the shear plate there is no problem with running the macro twice.
”Boost
”Tips
