I can find clip angle macros for single and double sided conditions but I can only find the beam/beam shear plate for a beam on one side. Is this connection available or do you just need to do it twice?
Solved by haydenwse. Go to Solution.
Can you please be more specific? What can you find and what you can't?
Regards.
I think I figured out why there is double sided beam / beam clip angle macro but only the single side beam / beam shear plate macro. On clip angles the bolts need to connect both sides so that needs to be a macro that does both sides together. On the shear plate there is no problem with running the macro twice.
