AutoCAD Structural Detailing General DIscussion
Valued Contributor
Priitl220
Message 1 of 7 (603 Views)
Dimensioning Styles: assembly and group - detailed view
603 Views, 6 Replies
01-23-2013 11:26 AM
If you use any of dimensioning styles from Group or Assemblies there is a tab "Detailed View".
How could I use it?
If I add Cross-section/Detailed View to template - it uses settings from "Front view " instead.
In properties it shows that ype is some mysterious "Custom View? (it should be "Detailed View" I think).
How could I change it to use setings from tab "Detailed View"?
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Active Contributor
talles.projetos
Message 2 of 7 (587 Views)
Re: Dimensioning Styles: assembly and group - detailed view
01-23-2013 05:06 PM in reply to: Priitl220
In plant. In front view and side view. You can use the keyboard command RBCS_ADDDETAILVIEW. Within any order to generate the detail view.
Was it?
Att
Talles
Valued Contributor
Priitl220
Message 3 of 7 (580 Views)
01-23-2013 10:46 PM in reply to: talles.projetos
Thank you for your effort, but this was not what I was looking for.
I know how to make cuts and details- I just need them to use the right style- not to change style one by one view.
StefanoPasquini6790
Message 4 of 7 (573 Views)
01-24-2013 02:09 AM in reply to: Priitl220
Good morning,
it's easy,
step 1) you have to create your personalized template with a detailed view (see picture below)
step 2) you have to select automatic cut in the format and scale label of the outomatic drawing command (see picture below)
and this is the automaic drawing result
bye
PasProStudio
Structural + Detailing engineers
Valued Contributor
Priitl220
Message 5 of 7 (545 Views)
01-24-2013 10:40 PM in reply to: StefanoPasquini6790
Thank you - but this was not it.
This option (you showed) only states where the section marks are shown - not the style of cuts.
(I know how to make templates.)
Try this. Activate the new section and click "Adjust Style" - What do you see?
zcsillag
Message 6 of 7 (508 Views)
01-27-2013 02:09 AM in reply to: Priitl220
Check this
Regards
Csillag Zoltán
Valued Contributor
Priitl220
Message 7 of 7 (466 Views)
01-27-2013 11:42 PM in reply to: zcsillag
Thank you. I do it like that, but I would like it to use the correct tab from same style.
You can do it by changing dimensiong style views one by one from general to detailed. Then it uses the settings from detailed tab.
But to change all views one by one is too tedious work,
So I should be able to set this via template.
Wishlist item or Bug?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
