I have modified my dimension styles, but the detail sheets that are automatically generated still maintain the same RBCS one that I had originally. What am I doing wrong???
Thanks for the suggestion. I just checked and my new dimension style is already set, but still it for some reasons still plots out as RBCS_Standard instead of what I set it to.
Did you set the new dimension style in all "style category": single part, assembly, group, scheme, and in all styles in each category?
Thanks for your very timely suggestions, however, I have done just as you depict, within assembly, but ASD ignores it and still auto gens as RBCS_STANDARD dim style regardless....
This is bad ASD dimension style ... all time made leader !
Subject: Regarding [CaseNo:08518128.] ASD dimension style without leader !
Body:
Hi Ion-Zoltan,
I understand your need for other complex solution. It is obvious for me.
There is a RBCS-15536 technical developement issue about this problem.
Best regards,
Jakub Brozonowicz
Hello, here is my project file with the dimension style issues. As you will see, I have set it to "AS BUILT PSPACE DIMLFAC 8" rather than RBCS_STANDARD, but the RBCS_STANDARD still gets used.
Geoff
