Hi All,
I'm trying to define standard parameters for a project in ASD. After you have defined a new set of parameters called i.e. NTC2008 (see picture) and after you have saved it as default, new projects don't use the new set but always the old one. This is a big problem because moving elements from the formwork module to concrete part of ASD the old default set of parameters is used.
Any suggestions?
Solved by Jakub.Brozonowicz. Go to Solution.
This set is part of job preferences.
It is therefore not possible to change these general settings for the program.
But you can do something very simple, which should suffice in this situation for a solution.
Simply create a save set as default and save the new template dwt.
For next new task just use such template.
