AutoCAD Structural Detailing General DIscussion
Distinguished Contributor
53 Kudos
Post 1 of 5
Customization of Connection
492 Views, 4 Replies
10-16-2012 09:26 AM
Is there any way to create the connection of structures to our need in ASD?, we need to customize more connections apart from the 65 nos which is avilable in the software. Please do help, I m new to ASD.
Valued Contributor
7 Kudos
Post 2 of 5
Re: Customization of Connection
10-17-2012 12:02 AM in reply to: Arun_Kumar_K
It can't be done. ASD doesn't accept User's macros.
12 Kudos
Post 3 of 5
10-17-2012 09:56 AM in reply to: lucis29
I do it all the time. What kind of connection are you looking to create?
There are little ways to trick the system :smileywink:
Valued Contributor
5 Kudos
Post 4 of 5
10-18-2012 09:34 AM in reply to: Arun_Kumar_K
Greetings, I'm interested too,
you know the way to create or customize connections? ....or just to trick them, it does no matter.
In my case the problem is that ASD does not recognize girder plate profiles as valid objects to make many connections : column-underside of beam / beam-column horizontal splice / beam (girder plate)-purlins...can you help me?
I've tried switching locations between profiles, no success, by this way just some connections are solved but others can't be done.
Valued Contributor
7 Kudos
Post 5 of 5
10-19-2012 12:45 AM in reply to: markhubrich
Hi Mark,
In the attachment I have an example of a Connection. You say that I can reuse this connection in another Project?
Or can I make a Custom macro out of this Connection?
If yes, please (briefly) tell me how.
Thank you!
Lucian.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
