AutoCAD Structural Detailing General DIscussion
Active Member
0 Kudos
Post 1 of 8
Criteria of Connections?
1101 Views, 7 Replies
10-18-2010 01:16 AM
I'm trying to do a two beams to column web connection, but when I select the relevant beams and column it tells me,  “Selected profiles does not meet criteria of this type of connection”. The beams are Universal Beams and the column is a Universal Column, so there's no reason why it SHOULDN'T work.
Is there a document anywhere stating what the "criteria" is?
Member
0 Kudos
Post 2 of 8
Re: Criteria of Connections?
07-22-2012 05:47 AM in reply to: danielledew
i have the same problem
7 Kudos
Post 3 of 8
07-23-2012 02:09 PM in reply to: danielledew
I've tested this out a couple times, without any problems yet.  Could you post up a screen shot or two of your current structure so I can more accurately duplicate it?
To my knowledge, I don't believe there is any criteria published beyond what is in the description.
Kyle Pope
Process and Power Specialist
ECAD, Inc
Our Blog
www.pdoteam.com
Product Support
32 Kudos
Post 4 of 8
07-24-2012 06:40 AM in reply to: kylepope
Maybe the angle between members is that criteria which accurately is not passed.
I'm able to answer (not guessing only) with true model sample.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Member
0 Kudos
Post 5 of 8
07-26-2012 01:24 AM in reply to: M_Azab
i faced this prolem when i use the connection column to rafter as shown in attached photo
Product Support
32 Kudos
Post 6 of 8
07-26-2012 03:43 AM in reply to: M_Azab
To make this connection possible to make due to such criteria you need to rotate column by 90deg.
Jakub Brożonowicz
Member
0 Kudos
Post 7 of 8
07-26-2012 04:59 AM in reply to: Jakub.Brozonowicz
the column and rafter have the same section therefore no need to rotate it
Distinguished Contributor
7 Kudos
Post 8 of 8
07-30-2012 07:11 AM in reply to: danielledew
danielledew wrote:
I'm trying to do a two beams to column WEB connection, but when I select the relevant beams and column it tells me,  “Selected profiles does not meet criteria of this type of connection”. The beams are Universal Beams and the column is a Universal Column, so there's no reason why it SHOULDN'T work.
 The beam web is parallel to the column's web. That's why it doesn't work.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
