AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Creating profile of my desired size and shape like RHS 1200*500*25 in ASD
11 REPLIES 11
Message 1 of 12
3924 Views, 11 Replies
I need to create some profiles which are not in the given profile list of ASD, such as, RHS 1200*500*25, W 600*300*25 etc . Is that possible? If so, how? If i use my defined sections, then woyld there be any problem in assigning the joints/connections in ASD?
I really need some quick suggestions.
S. M. Shafin Hasan
11 REPLIES 11
Message 2 of 12
zcsillag
Make Region and save User Sections
Regards
Csillag Zoltán
Message 3 of 12
in reply to: zcsillag
It worked, thanks a lot zcsillag.
How can I solve the problems in assigning the connections? For almost all connections with RHS sections, it says, "Selected profiles does not meet criteria of this type of connection". Is there any way to create user defined connections?
Message 4 of 12
zcsillag
Regards
Csillag Zoltán
Message 5 of 12
lucis29
ASD can't create custom connections. The most you can do is to "modify" an automatic connection.
Message 6 of 12
I have noticed that mass and thickness tf is zero in profile properties. I have attached an image regarding the issue. Is there any way to add mass or thickness to profile?
S. M. Shafin Hasan
Message 7 of 12
Tony_Gibbs
Yes you can do this easily if you know how to edit the xml file that holds the catalogue entry you made for the rhs
tonyp
Message 8 of 12
in reply to: Tony_Gibbs
I have found the profile database in C:\ProgramData\Autodesk\Structural\Common Data\2012\Data\Prof\ Aiscpro.xml, but after openning that file, I couldnt find the profile I assigned and saved as user profile in AISC database. Can you help where/how can I find that database?
Message 9 of 12
aaron_simpson
I'm using windows 7 and here is where I found the information on user sections after I made them:
C:\Users\"User Name"\AppData\Roaming\Autodesk\Structural\Common Data\2013\"DATABASE NAME"PRO.XML
Message 10 of 12
Tony_Gibbs
I use a program called "XML Notepad" to edit my XML files
My user sections are saved to a file called
C:\Users\UserName\AppData\Roaming\Autodesk\Structural\CommonData\2013\RUSERPRO.XML.
You will have to look through the profiles you have created to find the right one.
Notice in the attachment  there is a RED DOT entry for "MASS" just enter the weight here and so on
I hope this helps. If not let me know the details of the section you need to create and I will send you an XML file
Regards
Tony
Message 11 of 12
Tony_Gibbs
Forgot to add attachment
Message 12 of 12
MrLee710
I use Win XP, where i can find that. help me.
”Boost
”Tips
