AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Creating Holes Deleting Holes
9 REPLIES 9
Message 1 of 10
Geoff
1111 Views, 9 Replies
I have successfully generated holes thru two adjoining plates and their mating HSS Beam. However, I need to increase the hole size on one face only of the HSS beam, while keeping the plate holes the same size.  I isolated the beam, and changed the hole size successfully but it created another hole on the opposite side of the beam such as you would need if it were bolting through.  However, I am tack welding a Nut inside the enlarged hole and do not need a hole on the other side.  How can I achieve this?
Geoff
9 REPLIES 9
Message 2 of 10
zcsillag
in reply to: Geoff
Simple ... change software :S
Like Tekla...
Regards
Csillag Zoltán
Message 3 of 10
Geoff
in reply to: Geoff
What is the best way to delete holes that remain after I delete bolts?  Is there a way to modify bolt locations after they are drawn without deleting them and starting over?
Message 4 of 10
zcsillag
in reply to: Geoff
Regards
Csillag Z.
Regards
Csillag Zoltán
Message 5 of 10
Geoff
in reply to: zcsillag
Thanks Csillag! I noticed that I have some bolts facing the wrong way. Is
there a way to automatically re-orient them?
Message 6 of 10
Geoff
Thanks again Csillag!  One thing is unclear though.  How can I tell which hole I am modifying?
Geoff
Message 7 of 10
zcsillag
in reply to: Geoff
Hmm when select holes at dialog in model change color
Regards
Csillag Zoltán
Message 8 of 10
zcsillag
in reply to: Geoff
Message 9 of 10
tpham2001
Smiley Very HappySmiley LOL
But seriusly, we don't have the $$$ to do that.
Message 10 of 10
vanvan11
10X A LOT
save time
all the time when i make wrong placed bolts
”Boost
”Tips
