Recently I need to create a large number of Conical Sheet Metal in my project. All of them are with different size and thickness which causing me a lot of trouble to sort out the BOM in ASD. Is there any method to create the Conical Sheet Metal in ASD that are capable to detected as its part member such as plate?
Solved by jivkomitev2. Go to Solution.
You can do it from bent profiles. But take in mind in this case ASD can't make correct plate development. You have to do it yourself..
First define user section:
use bent profile command
result:
