AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
converting a revit model to ASD in order to add connections
1 REPLY 1
792 Views, 1 Reply
I have been able to export out of Revit a DWG file, which I can then open in ASD.  When opened in ASD the file(model)looks nearly the same as any DWG file created in ASD.  I tried to add connections, but nothing worked.  I repeated the process but only exported it as a ACIS file instead of a DWG.  I was able to create the file, but couldn't get ASD to open it. I have downloaded the ASD extensions.
Can anyone explain what I am doing wrong?
1 REPLY 1
Did you download the Revit extensions also?
”Boost
”Tips
