AutoCAD Structural Detailing General DIscussion
Member
RogerZimmer
Message 1 of 2 (575 Views)
converting a revit model to ASD in order to add connections
575 Views, 1 Replies
02-09-2011 08:43 PM
I have been able to export out of Revit a DWG file, which I can then open in ASD.  When opened in ASD the file(model)looks nearly the same as any DWG file created in ASD.  I tried to add connections, but nothing worked.  I repeated the process but only exported it as a ACIS file instead of a DWG.  I was able to create the file, but couldn't get ASD to open it. I have downloaded the ASD extensions.
Can anyone explain what I am doing wrong?
cgimpel
Message 2 of 2 (529 Views)
Re: converting a revit model to ASD in order to add connections
02-16-2011 07:44 AM in reply to: RogerZimmer
Did you download the Revit extensions also?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
