Good evening. I'm currently designing a beam support system for machinery in structural steel. Even though ASD manages some decent 3D modelling, I am required to deliver the same model on Inventor for design integration with my coworkers. I was wondering if there is any way you could convert the ASD 2D wireframe model into a full 3D solid model, in order to export the structure as an ACIS file for it to be opened with Autodesk Inventor.
Ivan Franco
Solved by zcsillag. Go to Solution.
Thank you very much, it completely worked. The procedure I performed was the following:
Model from ASD:
Model from Inventor:
